Cylinder upgrade
Cylinder upgrade
Postby Jono » Mon Jul 06, 2015 9:38 am
Looking for a little extra pulling power up hills , not really requiring extra speed from my GP 150 (Indian) running AF 42mm and 22mm jetex.
As a low cost option is it worth looking at a 175cc Iron Cylinder. If considered a viable option any views regards a Supplier of a good value bit of kit.
Views and advice appreciated.
Jono
Jono
Re: Cylinder upgrade
Postby Donnie » Mon Jul 06, 2015 9:59 am
Id say its definitly worth it, a well set up 175 is a great low cost boost for a scooter.
Remember you may have to look at gearing though that could be as simple as a front sprocket change.
I don't know about specific dealers but I would be looking for a genuine sil barrel, preferrably a genuine sil head (harder to come by than the barrels) and the thin 2 ring piston, usually Escort if memory serves unless you can get hold of the asso version, but im led to believe they are rare these days.
Donnie
Postby missing lynx » Tue Jul 07, 2015 8:46 pm
why don't you just get a 175 conversion piston and get your barrel rebored but if you clean up your ports do that first
Postby Jono » Wed Jul 08, 2015 12:00 am
Hi missing Lynx
Had thought about that some time ago and was quoted a silly price, appeared cheaper to buy a kit.
Maybe I should shop around outside of my local area for a better price - any idea what you would believe to be reasonable for such a rebore and piston?
Jono
Jono
Postby hullygully » Wed Jul 08, 2015 12:55 pm
REBORE & TUNE UP @ AF's, I THINK MY LAST ONE LAST YEAR WAS £160, + PISTON EXTRA
Postby Jono » Wed Jul 08, 2015 2:38 pm
Thanks all for info , greatly appreciated.
I assume as well as piston and rebore to 175cc a new 175 cylinder head will be required or can you also get 150 head re-worked?
Jono
Jono
Postby hullygully » Thu Jul 09, 2015 10:01 am
yup
Postby bolzenanker » Thu Jul 09, 2015 11:53 am
How about a Gori 175 kit from Rimini at £190 including barrel, piston and head. Seems good value?
http://www.riminilambrettacentre.com/en ... ccolo.html
bolzenanker
Postby hullygully » Fri Jul 10, 2015 11:14 am
why go for the Gori 175 kit when you can have the 200!! 8-) I'm well chuffed with mine after some UK tuning.... 8-)
Postby bolzenanker » Fri Jul 10, 2015 1:40 pm
Agreed, £50 more for the 200 Sport and £100 more for the 200 Race. :-)
bolzenanker
Postby Donnie » Fri Jul 10, 2015 3:41 pm
Does the 200 gori fit on small blocks then?
Donnie
Postby bolzenanker » Fri Jul 10, 2015 3:54 pm
Yep
bolzenanker
Postby Donnie » Sat Jul 11, 2015 3:46 pm
if the price compares well to a standard 175 then i guess that would be a good way to go for the op then.
Donnie
Users browsing this forum: Baidu [Spider] and 7 guests
