Puta Azul ( formally gumtree cutdown project)
Postby duncan1958 » Mon Jun 30, 2014 10:48 pm
I will endevour to post from start to where I am now with this project photos and text wise.
This is how I bought this unfinished project some years ago.
Collected parts over some period of time ,engine parts,seat,exhaust etc.
At the time of purchase I was going to be returning to live in the UK then things changed where I live so I boxed it up after dismantling with all the parts I had bought.
So here it is now sitting on a bench in my garage,this was last yearMay or June time.
Pizza box used for template before transfering to sheet steel.
Rear mudguard is fibreglass one trimmed down to suit,rear lamp is from Aprilla Habana also cutdown in height.
Side stand is modified from standard twist and go one bought from local flea market with piece of twisted bar left over from some building job.
Not sure I like the drop bars.
Should be sturdy enough mount for rear hugger.
Rear lamp close ups.
Filler work on legshields
Cleaning up of the horn casting
My mantra was dry build dry build
Dont like the gap between tank and frame tube.
So out with the fruit and fibre cereal box for another template this time for a tool box.
Even the seat is getting modified.
It will of course be recoverd.
Pulling apart for paint.
Now ready for primer.
Slight backwards step to fabricate mounts for front brake cylinder.
Trip to local bike breakers turned up this head lamp unit.
Oh and these handle bars.
Oh I now remember why I reassembled I would not have been able to work safely on the setting up of the handle bars etc on the bench.
Dash panel mock up in cardboard.
I went with a Lambretta speedo
Front wheel got polisehd by me before painting the centre.
Blue base goes on.
Then the blue metalflake
These photos of the frame painted were taken back in March of this year (I think)
I will upload more to photobucket of where I am at now in due course.
I felt I should take/make the effort to repost for all to see after loosing so much from the forum it was the least I could do.
duncan1958
Re: Puta Azul ( formally gumtree cutdown project)
Postby Rich Oswald » Tue Jul 01, 2014 9:15 pm
I am really liking this thread and just can't wait to see it finshed, top work my man,
Postby duncan1958 » Sun Jul 06, 2014 12:27 pm
Thanks for comments Rich,
Next batch of photos ,taken from the 12th of June up till last weekend.
Frame and all the parts came out of the house and back into my garage/workshop.
All assembly now being done on the floor because if I put together on the bench I would not be able to get the scooter off on my own.
Engine assembled new bearings, oil seals, clutch.
Mild clean up of ports and casing.
175 barrel piston head set up of unknown source apart from flea bay that is.
Front wheel engine in, along with leg shields etc etc
Cables and loom all run through the frame.
Tool box and other items gone on.
Carb was picked up at my local flea market for 15 euros if I remember its a PHBH 26mm will need rejetting but at that price it was a steal.
Now these levers you see here I quite like.
Because they do this.
Bend backwards not snap off .
Bought while on holiday,along with these mirrors and mounting brackets.
Starting to look like a complete scooter all be it a cut down one !
duncan1958
Postby Rich Oswald » Sun Jul 06, 2014 6:05 pm
Starting to look really good,
Users browsing this forum: No registered users and 8 guests
