So I've finished fitting a Varitronic to my S2 and now..... The lights are doing strange things!
I have a Casa key ignition switch fitted which was new only a few weeks ago and working fine prior to changing the ignition. I have a simplified loom, unsure what type as it was fitted prior to my ownership with an Indian electronic set up. I haven't changed anything in the headset that I'm aware of but I went on a shake down ride today and found the following;
Key position 1, ignition works as expected so does brake light and horn.
Key position 2, headset top/jewel light comes on with back light but no speedo light.
Key position 3, headlamp comes on and works on dip and main but the rear light and jewel light go out!
Headlamp bulb is a Readspeed Xenon, all other bulbs including tail light are LED's. I've also noticed the rear light and brake light are very dim and may have been before the ignition system change.
There are four wires coming out of the loom headset end, 2 reds, a green and a black. I know the green is the ignition and I guess one of the reds should be a live and the other two must go to the tail light?
Just wondered if this sounded familiar to anyone, I'm not great with a multi meter and not sure what I've done or what's causing it. I have run an earth from the coil to the regulator and from there to the frame then the mag housing. The rear light is separately earthed to the frame.
Any ideas anyone?
Cheers in advance.
