Only starts with NO air filter fitted !?
Postby Dobo » Mon Aug 24, 2015 4:55 pm
I have a RamAir filter and expansion exhaust, Jetex 22 carb, has been running ok! Now I run for short distance and it chokes up, smokes . . . choke is fine and OFF. Stop and remove RamAir and off we go. Why on earth is this happening guys. Any suggestions please?
Dobo
Re: Only starts with NO air filter fitted !?
Postby Wack » Mon Aug 24, 2015 5:43 pm
Tried riding with the panel off?
Postby peejay » Mon Aug 24, 2015 6:29 pm
is the filter clogged up?
Postby Adam_Winstone » Mon Aug 24, 2015 6:33 pm
Excessive bore/ring wear?
Postby Dobo » Mon Aug 24, 2015 9:06 pm
Yes tried with panels off . . . no joy. The RamAir is clean! Don't know about the cylinder or rings! How would that work anyway?
Dobo
Postby Raveydavey » Mon Aug 24, 2015 10:07 pm
If removing the filter makes it "fly" then the filter is restricting air excessively. Similar to putting your hand over an open carb....it's choking it. Clean/ wash/ replace the filter would be my first port of call
Raveydavey
Postby Dobo » Tue Aug 25, 2015 5:40 pm
Hi guys, thanks for responses. I got it wrong originally 'cos the scoot starts ok, ran for a mile-ish then choked up when we slowed down! :roll: I've given the RamAir a good clean in petrol, checked the plug and tried once more. Same result, choking and black smoke when we come to a stop!? HELP.
Dobo
Postby MickYork » Tue Aug 25, 2015 7:31 pm
give the carb' (pilot jet) a good clean. Check float bowl and filters for muck & gunge. try a new filter
