CHRIS in MARGATE wrote:Have you got some of air filter on there? If so, you'll have to remove it.
Rich Oswald wrote:Have a check to see if your clip on the needle has moved or even come off?
Warkton Tornado No.1 wrote:I presume this is a PHBH 30 mm.
Your symptons sound like you have the needle moving out of 'register' with the slide, alright on the way up, sticking on the way down. But how?
Although you say the "clip is still in place 2nd from the top" have you ensured it is under the needle retaining plate & not above it?
It would be an easy mistake to make.
hullygully wrote:good job you went in car to hand those stickers out on saturday![]()
Warkton Tornado No.1 wrote:Remember that if your jetting was anything like correct with the clip above the plate, you need to move the clip to a groove below & possibly more. You can fiddle to get fairly close with the shims that we all should have. I know I have some, it's finding them that is the problem....
Users browsing this forum: No registered users and 22 guests
