Nelly wrote:Funnily enough that's the chart I've been referring to for my bike Wack, but my CHT sensor is tapped straight into the head, not on the plug or under it. It's not affected by the cooling air.
I've been seeing some pretty crazy temps, but I've now sussed the happy areas and using it to set the jetting.
As an experiment I ordered a 2nd sensor and used Scotty's method of fixing to the top of the spark plug. I saw much, much lower temps when using this method. It really does depend on where the sensor is fitted.
