Nelly wrote:Scotty did mine for me, standard Jet 200 barrel with atomic reed conversion.
Had it out today trying to sort jetting and it's pulling really well. Still fine tuning though, there's a bit of a lean spot in midrange to address.
Drop him a message, I'm sure he will advise you what the best approach is for you.
Nelly wrote:It's a bit hard to say, as I changed carbs at the same time. I went from an Amal 30mm to a OKO 30mm, to a Dellorto PHBH 30mm. I gave up trying to set up the OKO, which is a PWK/Keihin copy. I've also changed from SX200 gearbox to Indian GP200 gearbox and changed the Scorpion expansion for a MRB Clubman too.
At the moment the Dellorto is set up with a 125 main, 50 pilot, x7 needle (3rd clip down) and AV266 atomiser, 40 slide, 300 float needle. It's close but not quite right yet.
Took it out today to get a few miles round town, it has quite a bit power but I'm suspecting it's still a bit lean in mid range.
