ignition timing in mm
Postby bert one » Tue Sep 15, 2015 9:04 pm
Hi, do any of you good folk know what 17° equates to in millimetres, & if so, how is the calculation made?
bert one
Re: ignition timing in mm
Postby Knowledge » Tue Sep 15, 2015 9:20 pm
Are you asking how many millimetres around the outside of the flywheel, or how many millimetres of travel before TDC?
Postby MickYork » Tue Sep 15, 2015 9:33 pm
I know "Bert" and I think he's asking about the marks on the mag flange, back from TDC. Would the measurement be "as the crow flies" or curved around the housing......if you get my drift
Postby bert one » Tue Sep 15, 2015 10:53 pm
Yeah, btdc. Going on the calculator it's 1.6mm ..... std' crank & rod (58/107).
Handy tool that ...... another one 'bookmarked'!
Thanks for sharing & thanks one & all for replies :)
bert one
Postby bert one » Tue Sep 15, 2015 11:02 pm
bert one wrote:Yeah, btdc. Going on the calculator it's 1.6mm ..... std' crank & rod (58/107).
Should have said I meant piston movement, which is what I'm after, as it's for setting the timing with a dial gauge as opposed to the 'positive stop' method prior to strobing :oops:
bert one
Users browsing this forum: Bing [Bot] and 6 guests
