rossclark wrote:The stroke is still 58mm it's the rod and the crown height of the piston that's different for the 175 crank.
You would need about a 8mm packer or find a piston with a crown height that matched that of the TV piston
Adam_Winstone wrote:TV Series 1 was 60mm stroke... so the question still stands.
Warkton Tornado No.1 wrote:I don't doubt that a crank with a stroke of up to 62 mm could fit & with a bore of, say Ø57 mm, utilising the transfer port area (@ the deck) available you could end up with a powerful, strong motor. Ultimately, a sleeved down large block cylinder would reap the best rewards.
I've said before that undersquare is the way to go with two strokes, as proven by MX bikes that have that format.
Warkton Tornado No.1 wrote:If your case is later Spanish it will have the larger transfer external area as per their 200 blocks.
Now, that likely configuration with ample meat on the cylinder walls probably would enable safe ditching of the fan. Refer to the 'debate' elsewhere! Ha!
BTW. The 175's were very smooth, IMO.
