ts1 jetting..
ts1 jetting..
Postby Scoot655 » Thu Sep 17, 2015 2:26 am
I've nearly finished the build of my ts1 motor and am after some baseline jetting info.it breaths through a 30mm flatside dellorto and im using a tsr evo exhaust. Using 47-18 sprockets and a long stroke crank.
many thanks.
Scoot655
Re: ts1 jetting..
Postby Toddy » Thu Sep 24, 2015 6:02 am
I Run this on one of mine with a Ram air filter
Dellorto 30 mm Flatslide VHSH/ADS3
Slide 40
Needle K21 P3
Atomiser DQ269
Main Jet 155
Pilot 45
Choke 60
Needle Valve 300
Re: ts1 jetting..
Postby Scoot655 » Sun Sep 27, 2015 10:28 pm
many thanks, will start from there. :)
Scoot655
Return to Carburettors
