Found an air leak! :-( Now what?
Postby Donnie » Wed Sep 30, 2015 2:55 pm
Still building the GT186 slowly and done a leak down test
It's hard to tell though exactly where its coming from? ie its looking like its coming from the upper cylinder stud on the mag side.
However, it's not coming via the base it's between the 1st and 2nd fin.
So, is it a leak via the stud and travelling up past the base gasket to the next spot and fixing it simply means removing the stud and replacing with loctite added to ensure no leak or is there something else going on?
Any help appreciated.
https://www.youtube.com/watch?v=gWxEDSZ_VCg
Donnie
Re: Found an air leak! :-( Now what?
Postby Captain Pugwash » Wed Sep 30, 2015 5:17 pm
You dont need to test above 8psi some test kits advise no higher.
Check the alloy around the barrel stud for damage if it's ok then likely it's the seal between the barrel and your engine case this is allowing air to travel from the primary chamber across the gasket face and out into the barrel stud hole thats where you can see it escaping between 2nd and 3rd fin.
Captain Pugwash
Postby dave411 » Wed Sep 30, 2015 7:04 pm
Have you used any type of sealent on your base gasket?
dave411
Postby Captain Pugwash » Wed Sep 30, 2015 8:45 pm
dave411 wrote:Have you used any type of sealent on your base gasket?
I don't often use a base gaskets, but if I do I use loctite 5922 gasket dressing.
Captain Pugwash
Postby Donnie » Thu Oct 01, 2015 10:52 am
just greased the gasket as I usually do to be honest.
Donnie
Postby Wack » Thu Oct 01, 2015 5:38 pm
Most of the gaskets are crap nowadays so I try to avoid as they split around the stud holes when the cylinder is torqued up.
Postby Donnie » Thu Oct 01, 2015 8:28 pm
This one was a reasonable one, ive had to take it apart, reseal everything again using some threebond liquid gasket but it's still got a leak but not as bad so im on the right track, im going to have to replace the stud and use some threadlock just to eliminate that I believe.
Donnie
