Sounds noisy
Sounds noisy
Postby Marrsy7 » Fri Oct 02, 2015 9:26 pm
Hi all had scoot for mot this morn (passed no probs ) so went 4 a ride running sweet as a nut pulled up at home left ticking over sounded really noisey from chaincase like slack chain but soon as put in gear noise stopped (chain tensioner ) ?
Marrsy7
Re: Sounds noisy
Postby Captain Pugwash » Sat Oct 03, 2015 7:41 am
Chain is still spinning when you e put it in gear but half your clutch and your gears dont spin once you put it into gear with the scooter not moving.
Rattling clutch or possibly gears might need shimming although the chain might still need adjustment
Captain Pugwash
Re: Sounds noisy
Postby MickYork » Sat Oct 03, 2015 8:18 am
either way it's side casing off and have a look.
Re: Sounds noisy
Postby Knowledge » Sat Oct 03, 2015 11:09 am
Might this be the kick start plunger being deployed? If the plunger cam is incorrectly adjusted, then the two teeth on the plunger can hit the corresponding teeth on the first gear.
As a test, pop the rebound rubber out of the outside of the side casing, and start her up. If the noise has gone when the kick start is at rest, then it indicates that the ramp inside the chain casing should adjusted. It is an easy but not foolproof test.
Don't forget to refit the rebound rubber afterwards
Users browsing this forum: Bing [Bot] and 6 guests
