Cluthch centre spring
Postby jonno » Fri Oct 09, 2015 7:06 pm
Going to fit a clutch centre spring. Is it held in place by the clutch nut and what do you do with the tab washer Does it require a nyloc nut to be used ?
jonno
Re: Cluthch centre spring
Postby rossclark » Fri Oct 09, 2015 7:40 pm
Don't think they're held in by anything other than the tension.
Postby LateAgain » Sat Oct 10, 2015 8:30 am
Just sits over the nut.
LateAgain
Postby hullygully » Sun Oct 11, 2015 6:01 pm
think you've got to trim the tab washer to make it fit
Postby Scooterlam » Sun Oct 11, 2015 7:58 pm
I can't rember trimming the tab washer on mine ,
Basically yes to the tab washer but ensure the spring sits flat.
Scooterlam
Postby HxPaul » Mon Oct 12, 2015 3:54 pm
Surely the spring cant sit flat because part of it sits on the tab washer,the part of the washer that locates on the peg on the clutch spider.
Postby Scooterlam » Mon Oct 12, 2015 5:09 pm
If you only bend up the tab to meet one of the six sides the spring will sit on 5/6ths of the washer.
The spring by the nature of its designed function Is pretty strong and is unlikely to distort into the UN supported 1/6th.
Untill the advent of the very good AF cassette clutch the perceived and therefore imparted wisdom was tab washers were essential. But as many will a test lochtite is now a proven method so if the uncertainty of that unsupported 1/6 th of the spring plays on your mind you could ditch the tab washer altogether.
BTW the spring only has one compressible coil so it really dosent make a hoot of difference any way.
Scooterlam
Postby Scooterlam » Mon Oct 12, 2015 5:15 pm
To awnser the OPs question the AF spring I have is a snug fit around the clutch nut
As an aside my phone auto corrects snug to anus.
Scooterlam
Postby Adam_Winstone » Mon Oct 12, 2015 5:20 pm
... have you set it to vibrate?!
Postby HxPaul » Mon Oct 12, 2015 5:23 pm
Great answer.The AF spring I have is a "anus" fit around the clutch nut. :o :lol: :lol: :lol:
Postby Scooterlam » Mon Oct 12, 2015 5:34 pm
Really have to read what your about to post.
Scooterlam
Users browsing this forum: Bing [Bot] and 8 guests
