Powder coating.
Powder coating.
Postby bricky36 » Sun Oct 18, 2015 3:04 pm
Does anyone know if I was to powder coat my
series 3 frame, would you still be able to see frame numbers?
Orso any good powder coaters round Watford way.
bricky36
Re: Powder coating.
Postby MickYork » Sun Oct 18, 2015 5:03 pm
If it was decent powder coating (primer/topcoat) you would be unlikely to see (or read clearly) the numbers.
Re: Powder coating.
Postby terryj » Sun Oct 18, 2015 5:18 pm
when i thad mine done i had to remove from around the numbers so i could do the rubbing for dating cert and then paint over
terryj
Re: Powder coating.
Postby 911hillclimber » Sun Oct 18, 2015 6:00 pm
The coaters I used new I would ask for the number not to be filled so went 'light' over the frame number.
You can still read it clearly. The coat is still good over that area, thicker elsewhere.
911hillclimber
Re: Powder coating.
Postby Toddy » Sun Oct 18, 2015 6:15 pm
911hillclimber wrote:The coaters I used new I would ask for the number not to be filled so went 'light' over the frame number.
+1 :D
Re: Powder coating.
Postby JETEX » Sun Oct 18, 2015 11:51 pm
I took a rubbing off mine for the LCGB dating certificate, and photographed it before the frame was powder coated. You can barely see the numbers now, but I've painted the indentations so I hope this will satisfy an examiner if need be when I come to get it registered.
JETEX
Re: Powder coating.
Postby bricky36 » Mon Oct 19, 2015 9:18 am
I thought frame numbers had to be clear at all times, (in case stopped by police etc).
Maybe I am wrong, will have to find out.
Thanks for replies.
bricky36
Re: Powder coating.
Postby Scooter Paul » Mon Oct 19, 2015 11:20 am
I have a very thorough MOT guy. He checks the frame number every time even though I've been taking the same scooters to him for years.
Paul.
Scooter Paul
Re: Powder coating.
Postby bricky36 » Mon Oct 19, 2015 4:08 pm
Scooter Paul wrote:I have a very thorough MOT guy. He checks the frame number every time even though I've been taking the same scooters to him for years.
Paul.
So I guess it is important to keep frame numbers visible.
bricky36
Re: Powder coating.
Postby gaz_powell » Mon Oct 19, 2015 4:30 pm
the coating on my indian frame is very good and with done with a bit less over the numbers - As we all know Indian numbering is s+#te but are still legible and were checked at inspection when it was registered.
My API S2 was done the same way
A good powder coater is what you need
Gaz
Re: Powder coating.
Postby Rich Oswald » Mon Oct 19, 2015 4:48 pm
JETEX wrote:I took a rubbing off mine for the LCGB dating certificate, and photographed it before the frame was powder coated. You can barely see the numbers now, but I've painted the indentations so I hope this will satisfy an examiner if need be when I come to get it registered.
Best advice anyone could give :D
Users browsing this forum: Google [Bot] and 12 guests
