Why don't nothing fit
Postby jonoy » Sun Nov 22, 2015 10:14 pm
Had to take my headset and light out
Why is it that the headlight rim won't fit back on the headset straight
Benn messing about with it for 2 hours when you get rim on screws won't do up
I wished I had a Vespa
jonoy
Re: Why don't nothing fit
Postby Knowledge » Sun Nov 22, 2015 10:38 pm
Herachy
Postby jonoy » Sun Nov 22, 2015 10:44 pm
Must be me it fitted before I took it apart
Headlight rim a pain in the butt
jonoy
Postby carlos fandango » Sun Nov 22, 2015 11:23 pm
its a test ..........from the Innocenti gods .....if give up , you'er not worthy ......and demoted to a v£$p@ owner :D
carlos fandango
Postby jonoy » Sun Nov 22, 2015 11:49 pm
I am so tempted
jonoy
Postby Toddy » Mon Nov 23, 2015 7:08 am
carlos fandango wrote:its a test ..........from the Innocenti gods .....if give up , you'er not worthy ......and demoted to a v£$p@ owner :D
:lol: :lol: :lol:
Postby HxPaul » Mon Nov 23, 2015 10:25 am
jonoy wrote:Had to take my headset and light out
If you've had the headset top off,make sure you havn't trapped a wire when you put it back on,if you have the top will sit proud and stop you from fitting the rim.
Postby dave81 » Mon Nov 23, 2015 12:57 pm
Know exactly what you mean with my GP. I offer the rim up and then start the screws winding them in carefully to pull the rim in square. If the screws start to feel tight then I push the rim in further.If the screws go too tight then undo them as you don't want to strip the threads.Even though this normally works for me the rim is never a perfect fit all round.
dave81
Postby coaster » Mon Nov 23, 2015 1:53 pm
Is it a Special headlamp rim? I find it best to do the 2 big screws up part of the way then fit the bottom 2 rim screws, push down on the headset top and engage and partially tighten the top 2 rim screws. Then push down on the headset top and push the rim into place, this sometimes requires a bit of banging on the headset with my fist. then tighten all 4 rim screws but not all the way. Final tighten of the 2 large screws and last of all, final tighten of rim screws. I would think the GP is similar.
Postby Angry Bloke » Mon Nov 23, 2015 1:55 pm
I would slacken the screws which hold the top and bottom together and then fit the rim as often they can cause the headlamp hole to splay :D
Angry Bloke
Postby Tractorman » Mon Nov 23, 2015 5:06 pm
Angry Bloke wrote:I would slacken the screws which hold the top and bottom together and then fit the rim as often they can cause the headlamp hole to splay :D
Learned this years ago never tighten anything until all bolt/screws are in. ;)
Postby Marty ULC » Mon Nov 23, 2015 9:56 pm
That's how I fit mine, big screws in very loosely just so they catch then fit and tighten the small ones to hold the rim in place without putting too much strain on the threads, then tighten the big ones up fully. Always push the parts together with my other hand while tightening to avoid stripping the threads.
Normally then find I've knocked out a wire in the process and have to do it all over again
Marty ULC
Postby citydaz » Mon Nov 23, 2015 11:19 pm
Urrr....... I took your advice and bought a V***a P200E frame from fleabay on saturday. It will keep my LI125 III company in the garage! :o
citydaz
Postby Garbo » Tue Nov 24, 2015 9:16 am
Nothing wrong with a Vespa P200E, good reliable scooters
Garbo
