by Norrie Bodge » Tue Nov 24, 2015 9:51 pm
Lads
Does a GP long range tank fit in a S2 LI-150
The type that retains the toolbox
Norrie Bodge
by Toddy » Wed Nov 25, 2015 7:12 am
I didn't know you got a specific GP long range tank I thought they suited all series 1/2/3 , I've fitted the Far east long range tanks in Series 2's fit ok some a bit tight and fiddly to get in, also fitted the SSP 13 litre in a series 1/2 which was a better fit , so I would say yes
by corrado » Wed Nov 25, 2015 4:09 pm
The Viet ones that fit with longer straps as per normal tanks fit OK, though as Toddy says they're a tight fit. The Viet type that bolt in require that the cups that hold the bottom tank rubber in place need the sides bending flat or removing.
corrado
by Tractorman » Wed Nov 25, 2015 4:29 pm
Toddy wrote:I didn't know you got a specific GP long range tank I thought they suited all series 1/2/3 , I've fitted the Far east long range tanks in Series 2's fit ok some a bit tight and fiddly to get in, also fitted the SSP 13 litre in a series 1/2 which was a better fit , so I would say yes
SSP?
by Toddy » Wed Nov 25, 2015 4:31 pm
Tractorman wrote:Toddy wrote:I didn't know you got a specific GP long range tank I thought they suited all series 1/2/3 , I've fitted the Far east long range tanks in Series 2's fit ok some a bit tight and fiddly to get in, also fitted the SSP 13 litre in a series 1/2 which was a better fit , so I would say yes
SSP?
http://www.stainlessscooterproducts.com
by Tractorman » Wed Nov 25, 2015 7:19 pm
Toddy wrote:Tractorman wrote:Toddy wrote:I didn't know you got a specific GP long range tank I thought they suited all series 1/2/3 , I've fitted the Far east long range tanks in Series 2's fit ok some a bit tight and fiddly to get in, also fitted the SSP 13 litre in a series 1/2 which was a better fit , so I would say yes
SSP?
Thanks Mr. Todd
by burnside » Wed Nov 25, 2015 10:56 pm
I've got one of the Oiltek midrange tanks in my S2, not the cheapest but great quality and very easy to fit as bolts in so no straps required
burnside
Users browsing this forum: No registered users and 8 guests
