s3 long range tank in s2
Postby Norrie Bodge » Tue Nov 24, 2015 9:51 pm
Lads
Does a GP long range tank fit in a S2 LI-150
The type that retains the toolbox
Norrie Bodge
Re: s3 long range tank in s2
Postby Toddy » Wed Nov 25, 2015 7:12 am
I didn't know you got a specific GP long range tank I thought they suited all series 1/2/3 , I've fitted the Far east long range tanks in Series 2's fit ok some a bit tight and fiddly to get in, also fitted the SSP 13 litre in a series 1/2 which was a better fit , so I would say yes :D
Postby corrado » Wed Nov 25, 2015 4:09 pm
The Viet ones that fit with longer straps as per normal tanks fit OK, though as Toddy says they're a tight fit. The Viet type that bolt in require that the cups that hold the bottom tank rubber in place need the sides bending flat or removing.
corrado
Postby Tractorman » Wed Nov 25, 2015 4:29 pm
Toddy wrote:I didn't know you got a specific GP long range tank I thought they suited all series 1/2/3 , I've fitted the Far east long range tanks in Series 2's fit ok some a bit tight and fiddly to get in, also fitted the SSP 13 litre in a series 1/2 which was a better fit , so I would say yes :D
SSP?
Postby Toddy » Wed Nov 25, 2015 4:31 pm
SSP?
http://www.stainlessscooterproducts.com
Postby Tractorman » Wed Nov 25, 2015 7:19 pm
Toddy wrote:
SSP?
Thanks Mr. Todd
Postby burnside » Wed Nov 25, 2015 10:56 pm
I've got one of the Oiltek midrange tanks in my S2, not the cheapest but great quality and very easy to fit as bolts in so no straps required :D
burnside
Users browsing this forum: No registered users and 8 guests
