rear hub bearing size
Postby Drewster51 » Thu Nov 26, 2015 11:44 pm
HI All
I'm trying to fit rear hub bearings and it seems very very tight I have used some Vernier callipers to measure the bearings and layshaft etc.
1979 GP200 india
Layshaft 24.91mm Bearing inner 24.86mm 0.05mm smaller
Gearbox 51.79mm Bearing outer 51.97mm 0.18 bigger
:oops:
is it me or is that too much
CHEERS
Drewster51
Re: rear hub bearing size
Postby JETEX » Fri Nov 27, 2015 2:17 am
Stating the obvious, but have you tried heating the casing ?. I find it better to use a hot air paint stripper gun rather than a naked flame.
JETEX
Postby HxPaul » Fri Nov 27, 2015 11:25 am
HI All
1979 GP200 india
:oops:
From your post its not quite clear what you are trying to fit.If its the hub bearing into the case,then you should heat the case,as JETEX says to fit the bearing.What the layshaft and gearbox have to do with fitting the rear hub bearing,I'm at a loss to see :?:
Postby hullygully » Fri Nov 27, 2015 1:13 pm
Is it an Innocenti layshaft? as some Indian layshafts/rear hub brgs tolerances can be a smidging out on the Italian ones :o
that's why there's a market for used / 2nd hand GOOD Italian rear hub brgs :D
Postby Drewster51 » Sat Nov 28, 2015 5:47 pm
Hi All,
Thanks for the replies.
I have tried heating the casing with no joy so I got in touch with the supplier of the bearings and they said to put bearings in the freezer !!!
then heat the casing.
I have done this and the bearings fitted like a glove.
I also put the layshaft in freezer and heated the inside of the bearing and the layshaft also fitted like a glove with no problems after putting everything back together.
Thanks again
Drewster51
Users browsing this forum: Bing [Bot] and 9 guests
