How are you fitting these on to the forks people?
Cheers.....
Warkton Tornado No.1 wrote:I believe that the subject of Kawasaki steering dampers has been covered many times & for good reason. However, you may be unaware that they ruin the handling of a front damper equipped fork.
With suspension, the spring is there to take any shock load & damping is required mostly for rebound to control oscillation that may otherwise occur, hardly any for 'dive' or compression.
Steering dampers won't provide those requirements as they are consistent in both directions.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
