Variatronic "Wassell" conversion
Re: Variatronic "Wassell" conversion
Postby Dimitrios_231 » Wed Nov 25, 2015 1:32 pm
Job's done :D :)
Mr Captain rocks 8-)
Dimitrios_231
Postby Wack » Wed Nov 25, 2015 7:06 pm
And then there was two 8-)
Postby Dimitrios_231 » Wed Nov 25, 2015 9:08 pm
:D ;)
Checked the correct length of the wires,cut them and fitted the bullet terminals.
I used the test bike that I only have for this task :mrgreen:
It was a good time to also check the fitment of a new velocity stack on a spare right handed Amal,
mmmm, I'll have to make one more hole on one more original SX200 panel,sorry Mr Innocenti :lol:
Dimitrios_231
Postby Jamjo » Thu Nov 26, 2015 7:36 pm
Nice clean work , going to have a pop at this as well but don't think my surroundings will be that clean and tidy :lol:
Jamjo
Postby Dimitrios_231 » Fri Nov 27, 2015 12:41 pm
It's not a beauty contest :)
the only thing that matters,is to work ;)
Some of the regulators that can be used.
Dimitrios_231
Postby Dimitrios_231 » Sun Dec 06, 2015 7:47 pm
I strobed it earlier,so far everything is fine,
I'll report about the lights later...
Dimitrios_231
Postby Dimitrios_231 » Tue Dec 22, 2015 8:23 pm
Testing finished,
lights are very bright and steady,night riding is safe,not afraid of the dark :) I use standard type bulbs front and rear,no led,no halogen,
my Lucas are also working perfectly but I'm not going to remove the covers,
I'll do in the future a similar conversion on another lammy that has the Lucas spots uncovered,I'll post a video then.
Exhaust,carb,cylinder and gearbox are working in harmony,I'm satisfied.
Teaser video.
The rattling noise is from the inner front disc at the hub.
Use hearing protection ;)
Dimitrios_231
Postby Captain Pugwash » Wed Dec 23, 2015 12:20 am
Result 8-)
Captain Pugwash
Postby Jamjo » Wed Dec 23, 2015 9:10 am
Looks great , I tackled mine and to my surprise I went quite well. Other tan fixing the cable tie on the wrong side so hindered refitting but soon sorted . Thanks Mark (Captain ) and Dimitrios for all the input :D
James
Jamjo
Postby Dimitrios_231 » Wed Dec 23, 2015 10:25 am
That is great James,join the club :) ;)
I haven't done anything,Captain is the man,
thank you Captain (again :) )
Dimitrios_231
Postby Dimitrios_231 » Tue Feb 09, 2016 2:09 pm
The ultimate disguise,modern 12V Italian DC variable ignition with vintage look.
Dimitrios_231
Postby jonashford » Tue Feb 09, 2016 6:48 pm
This isnt a varitronic, its a casatronic?
jonashford
Postby Dimitrios_231 » Tue Feb 09, 2016 10:15 pm
Casatronic/Parmakit ;)
the stator is similar to Varitronic.
Dimitrios_231
Postby Dimitrios_231 » Sat Feb 13, 2016 9:10 pm
The complete variable DC conversion,
modern technology,vintage look,
it wasn't easy but I prefer it this way.
Dimitrios_231
Postby Nelly » Sat Feb 13, 2016 9:16 pm
Lovely job.
Nelly
Postby Dimitrios_231 » Sat Feb 13, 2016 9:37 pm
Cheers ;)
Dimitrios_231
Postby gazza » Wed May 18, 2016 5:33 am
Hi i'm interested in attempting this conversion I have recently done a re-build and have a varitronic and as i'd added a couple of pathfinders i decided to add a battery and run everything via the battery (DC - from bgm pro regulator) apart from the main headlight (AC). I tried to use a relay to operate the DC circuit i.e when ignition switch is on operate the relay, but as it was AC and only giving an output of around 8v the relay(12 v dc) would not operate correctly and chattered.
Quick question what output does this conversion give at low revs ie tick over- will it drive a 12v dc relay ? And would there be enough power to run 35w headlight, dc horn, led rear light, and occaisional pathfinder (either fog or spot)?
cheers
Gazza
gazza
Postby Adam_Winstone » Wed May 18, 2016 5:54 pm
Over the last couple of years I've been changing away from DC setups (12V and 6V), for the maintenance-free AC option, so have no intention of playing with these but thought I'd drop a line to say, "What an interesting read!" Very informative and up to the Captain's usual high standards. Dimitrios has done a fine job with his setup too :)
Nice work guys and thanks for sharing.
Adam
Postby Dimitrios_231 » Wed May 18, 2016 8:43 pm
:) The hardest part of the project was to wait for the Italian post to send me Tino's vintage look CDI for Varitronic.
Captain did a fantastic job with the mod.
Gazza, it will probably support original lamps but it will be much better if you use LEDs at the pathfinders.
A video with AC 35W headlight and 12V LEDs Lucas fed from the battery :) ,
DC is much much better now but I don't have a video,all the lights are steady even at tickover.
Dimitrios_231
Postby Lord-Spanner » Sat Jun 24, 2023 3:59 pm
What a great read of a very old post and good pictures too, this is just what I'm after to convert to full Dc on a varitronic system :mrgreen:
Lord-Spanner
Users browsing this forum: stephena and 5 guests
