Cush drive bid for freedom!
Postby Lammer205 » Sun Jul 13, 2014 2:59 pm
Hi all , i've just rebuilt a motor and thought all was spot on torqued up and shimmed etc, back in the bike and go to start it kickstart very stiff and not returning gave it a few kicks to try and start it , more out of frustration i think, then stopped sat down beside the scoot for a relax smoke and notice a hairline crack on the polished casing at cush drive so casing back off and yes damage as if the cush drive made a bid for freedom through my casing,so why did this happen, whats wrong and how do i fix this?thanks Lammer205
Lammer205
Re: Cush drive bid for freedom!
Postby mcbrid » Sun Jul 13, 2014 4:16 pm
Could be you didn't seat the retainer on the splines properly and therefore when you thought you were torqued up you had actually just tightened up against the spring.
Mate of mine did this a few weeks ago and he got the case welded up and replaced the cush and its fine.
mcbrid
Postby soullad » Sun Jul 13, 2014 5:30 pm
mate of mine had his bolt wear thru the side casing whilst on the coast to coast ... riding some 10 yds behind him, I thought I saw something fall off his bike but didn't take any notice. 50 yds later and he stops and we notice a neat hole in the side casing ... game over !
soullad
Postby Lammer205 » Sun Jul 13, 2014 6:39 pm
Yep cush drive not seated properly in my haste to get this running :oops: , now i need a new cush drive and also sort the casing out :x , thanks Lammer205.
Lammer205
Postby MickYork » Sun Jul 13, 2014 7:34 pm
Used JB Weld when i did the same and put a crack in my casings.....Just done Kelso, Newark and Cleethorpes and no leaks or problems.
Postby Lammer205 » Sun Jul 13, 2014 7:48 pm
Thanks for that Mickyork, gonna bring casing to work tomorrow and clean it up and see can i fill it , cheers Lammer205.
Lammer205
Postby northeast town » Thu Jul 17, 2014 9:44 pm
when i fit the cush drive,i tighten up just enough so you can still turn the drive assembly washer by hand, then very lightly tap the washer with a hammer (not a rubber or plastic hammer) turning it at the same time, you will feel/hear it locate properly.it will all so feel springy/bouncy when located,then tighten up properly,
northeast town
Users browsing this forum: Bing [Bot] and 24 guests
