by panda » Thu Jan 07, 2016 10:56 pm
Need advise on drilling a hole in the under headset for the hose but what's the best drill bits to use and where can you buy the grommets for the hole
panda
by CHRIS in MARGATE » Thu Jan 07, 2016 11:06 pm
Put masking tape around the intended area in case drill slips. Drill small pilot hole first. Increase size and use the drill bit as a router to get size right. Good quality HSS bits are all you need.
Pack of assorted grommets from Halfords; The Range; B and Q.
It is surprisingly easy to do.
by CHRIS in MARGATE » Thu Jan 07, 2016 11:08 pm
Meant to add: You have to go lower than it first looks because headset top sits down over the base and if pipe not low enough you can't get headset top on without forcing it.
by panda » Thu Jan 07, 2016 11:33 pm
Thanks very much for your info
panda
by Mag » Fri Jan 08, 2016 8:32 am
I always cut a slot in the headset bottom, rather than a hole. Cot it so the headset to forms the top of the hole and still use a grommet.
this makes fitting and removal a lot easier and looks as neat.
Mag
by Freight10 » Fri Jan 08, 2016 10:51 pm
Panda, when I did mine, I used masking tape across the top of the headset, then I used a file and filed the slot until it sat properly over the bottom of the headset without crushing the hose.
This way if for whatever reason I may want to revert back then I only have to get a new headset top.
Freight10
by Storkfoot » Fri Jan 08, 2016 11:17 pm
Freight10 wrote:......
I wouldn't worry unduly as a competent alloy welder can sort out a gaping hole in a headset top or bottom
by panda » Sat Jan 09, 2016 2:43 pm
Thanks everybody for your replies l filed a slot in the under headset and it sits nice and snugg but two more questions l noticed it has a brake switch can you wire these up and if so where too and the disc brake am using is the pepperpot one and it only has one nut on the hub side and none on the other
panda
by shane BBoys » Sat Jan 09, 2016 4:36 pm
Follow the hose with your cables through the horn cast then route to the brake pedal switch and connect there. try the brake once connected if the brake lights do not work switch them around at the top,
Cheers Shane
shane BBoys
by Norrie Bodge » Sat Jan 09, 2016 6:35 pm
did mine like this on my GP & S2.... really neat job
Norrie Bodge
by corrado » Sun Jan 10, 2016 2:24 am
panda wrote: the disc brake am using is the pepperpot one and it only has one nut on the hub side and none on the other
That's how it should be.
corrado
by CHRIS in MARGATE » Sun Jan 10, 2016 9:40 am
I took 1 wire from new switch to a live in headset and a 2nd wire from the other terminal through the frame and spliced it into the brake light wiring above the rear mudguard.
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
