Which small block kit?
Re: Which small block kit?
Postby Marty ULC » Fri Jan 22, 2016 1:38 am
I've gone for a GT186 kit with 30mm phbh and a JL3.
I'm waiting to see how Donnie and shamrock express get on with their gearing before I decide on chains and sprockets.
Marty ULC
Postby Warkton Tornado No.1 » Fri Jan 22, 2016 2:16 pm
I think you've made a wise choice.
However, just because you've had no response to your questions:
Also would the series 1 side case be up to the job and will the standard throttle wheel have enough travel to open the carb fully?
Don’t take a chance on the crankcase cover if you are referring to the thought of upgrading your kick-start area to cope with any rise in compression. I've broken SII & SIII covers so pay heed to my mistakes!
Sticky’s excellent ‘bible’ covers it in detail.
As for the throttle pulley, 30 mm carburettors & above need a modified gear-change pulley/headset or equivalent, IMHO.
Postby bazza3004 » Fri Jan 22, 2016 6:04 pm
Hi not sure if this has been said already but if you have the GT kit you would benefit from a 16 t front cog with the Li150 box as it is quite a torquey little kit and will pull this gearing no problem.(unless your 30 stone etc )
bazza3004
Postby Marty ULC » Fri Jan 22, 2016 6:37 pm
I've got an SIL chain case cover knocking about so that'll probably go on then.
Had been thinking 16/46 but will see what the feedback from the others is before splashing out on anything. My bank account needs to recover a bit first, despite getting a good deal from Mr Corrado on the kit.
I'd guestimate size wise I'm somewhere in between donnie and shamrock express.
Marty ULC
Postby bazza3004 » Sat Jan 23, 2016 1:22 am
There is a fair bit of info on the GT kit written by richard taylor im sure someone will post the link to it .
bazza3004
Postby Toddy » Sat Jan 23, 2016 9:21 am
Here's a link to the website
http://www.granturismo.pwp.blueyonder.co.uk
Postby Donnie » Sat Jan 23, 2016 12:35 pm
Marty ULC wrote:I've got an SIL chain case cover knocking about so that'll probably go on then.
Jaysus, Shamrock Express must be HUGE :lol: :lol: :lol: :lol: :lol: :lol:
Donnie
Users browsing this forum: Bing [Bot] and 7 guests
