Donnie wrote:Beginning to think theres something either actually wrong with it or there was something in the relay box I need.
Might just buy this one and start again, it's much simpler looking as i just wire the three wires into the current 3 pin plug
http://www.ebay.co.uk/itm/35W-Motorcycl ... Sw~bFWOx0r
MK Monty wrote:Donnie
It would seem from your video that it's failing to spark the beam. I have heard that this flicker can be a problem with some units. It may be that your unit has some other caps or something to smooth the power in your little black boxes. I know Coaster has not got them fitted. Mine has a multi terminal contact relay and I'm sure it's doing more than turn it to dip f full beam. Going back to your kit was it the same when you had the relay connected? I thought it was lighting up just not flicking up and down. I bought the car one so got 2 of everything so had spares. May be the way to go if you want to get another kit
Donnie wrote:Coaster, Im happy to extend the wiring, already got a pair of extension wires for exactly that which is why im thinking i might buy the simpler box one like on your jet.
However, im intrigued by the car one you also had with the shroud, did that not have relays etc too?
MK Monty wrote: No offence Donnie, you will get it sorted in the end.
Marty ULC wrote: .....It's getting my head around where the power feed comes in and how to wire up a relay that I'm likely to struggle with, am I right in thinking I can't just wire it up through the switch directly?
Donnie wrote:...then I also tried something that several websites said to try, ie reverse the polarity
