what is the correct Atomiser
Postby kennystag » Mon Feb 15, 2016 2:08 pm
Hi All,
I Have been getting deferent stories, when reading on the internet, as to what is the correct Atomiser to use on my GP150 cc with a 22 mm Jetex carb, some say it is 5899/2, and others say 5899/4, any thoughts.
Stag
kennystag
Re: what is the correct Atomiser
Postby rossclark » Mon Feb 15, 2016 2:16 pm
Postby ToBoldlyGo » Mon Feb 15, 2016 2:29 pm
Should be 5899.4 with the cutout in the slide for the 150.
ToBoldlyGo
Postby kennystag » Mon Feb 15, 2016 2:34 pm
Thanks for the comments. I got my atomiser 5899/2 from SR, have a look ,click on the number and it takes you to the part.
Stag
http://www.scooterrestorations.com/imag ... excarb.asp
kennystag
Postby Donnie » Mon Feb 15, 2016 6:32 pm
the 2 is the richer atomiser and fitted to the 175s and 200 mainly, along with the slide that has no cut out.
Certainly when I ran a jetex on a 175, or a mugello I changed to them for a richer midrange.
Donnie
Postby HxPaul » Mon Feb 15, 2016 6:35 pm
Postby kennystag » Mon Feb 15, 2016 7:49 pm
Yes it list 2 atomisers. click on 17 on there diagram.
Stag
http://www.scooterrestorations.com/lamb ... 9-2-jetex/
kennystag
Postby dave81 » Mon Feb 15, 2016 9:57 pm
I changed all the jets on my Gp150 sil to standard as per 'stickies' list in the back of his manual.
When I first got it I had trouble getting the mixture screw to make a difference to the idle speed. The pilot jet was 48 so I standardised it to a 45. I decided to fit all dellorto jets as they are stamped to the size. The carb is a jetex 22mm and the jets are 45 pilot, 50 choke,118main jet,7895-2 slide, 58994 atomiser.
dave81
Postby kennystag » Tue Feb 16, 2016 2:42 pm
Thanks for the comments. Does any one know which holes that are measured to determine the atomizer size.
Stag
kennystag
Users browsing this forum: Baidu [Spider] and 8 guests
