Scomadi replacement gp forks
Postby Kristof Lammy pie » Tue Mar 15, 2016 5:07 pm
Anyone had any scomadi replacement forks?
Just wondered what sort of quality they are.
http://m.ebay.co.uk/itm/172133853580
Kristof Lammy pie
Re: Scomadi replacement gp forks
Postby nickw » Tue Mar 15, 2016 6:58 pm
A friend bought some. He says they are very well made and worth the money. He also commented that at least they were straight unlike 2nd hand forks on eBay
nickw
Postby Kristof Lammy pie » Tue Mar 15, 2016 9:26 pm
Cheers just bought a set.
Kristof Lammy pie
Postby foremanbob » Fri Mar 18, 2016 12:43 pm
i believe that there has been an issue with the positioning of the upper damper brackets
foremanbob
Postby Kristof Lammy pie » Fri Mar 18, 2016 1:01 pm
foremanbob wrote:i believe that there has been an issue with the positioning of the upper damper brackets
Mine have just arrived. Hopefully mine are ok.
Kristof Lammy pie
Postby corrado » Tue Mar 29, 2016 10:47 am
Early GP ones had the groove for the headset bolt too low so you had to file it longer by about 3mm. It was easier to elongate the slot than it was to return them. I never bought any more but this issue was raised by Sticky in an article in Scootering Rag at the time so presumably they rectified the fault, though I can't confirm that.
corrado
Postby Digger » Tue Mar 29, 2016 12:03 pm
I've just had to fettle a pair of Scomadi Jet forks for a similar issue.
Digger
Postby Lockman69 » Tue Mar 29, 2016 12:53 pm
corrado wrote:Early GP ones had the groove for the headset bolt too low so you had to file it longer by about 3mm. It was easier to elongate the slot than it was to return them. I never bought any more but this issue was raised by Sticky in an article in Scootering Rag at the time so presumably they rectified the fault, though I can't confirm that.
Wish I had read that article :evil: ...after fecking about for ages with a set of LI Scomadi forks I eventually came to the same conclusion and the same fix... :)
Lockman69
Postby corrado » Tue Mar 29, 2016 11:01 pm
Actually now I think about it the stem length was 3mm short when measured against several Italian and Indian GP forks and elongating the slot was the only way to make then usable.
corrado
Postby Lockman69 » Wed Mar 30, 2016 9:03 am
My LI forks did measure up to the sizes given in the Sticky book and matched a bent pair they where replacing, but the pinch bolt position was in the wrong place :o
Lockman69
Postby Kristof Lammy pie » Wed Mar 30, 2016 3:45 pm
I'm hoping the next set I get are all correct, but getting doubts already.
Kristof Lammy pie
Postby nickw » Wed Mar 30, 2016 7:54 pm
Well I'm shocked by the adjustments some have made. As far as I can remember my mates GP forks went in with very little fettling
nickw
Postby Digger » Thu Mar 31, 2016 7:58 am
You'd think they'd go in without no fettling at all.
Digger
Users browsing this forum: Bing [Bot] and 5 guests
