Tried fitting the LTH clutch today,did up the centre nut just tight,and the whole thing was solid.(I have 2 shims behind it to give clearance to the iwis chain).Took it off again and found the bush on the spider had a small crack in it,I suppose tightening it up spread the bush and locked it all up.I hadnt noticed it before,although it didnt spin well when dry assembled,it had a tight spot. I did dremmel an oil groove in the bush and the split is opposite that,though I cant see how that would affect it.Anyone had this happen and any tips on fitting the LTH,I'm guessing its straightfoward like the standard item.
Users browsing this forum: Bing [Bot] and 6 guests
