by Knowledge » Wed Mar 16, 2016 10:05 pm
I have an Acewell speedo and it is a good bit of kit. I'm likely to buy another.
Mine has a fuel gauge, but the version listed has a temperature gauge instead. Has anyone got any experience of an Acewell with a temperature gauge. Can it work with an exhaust temperature gauge, or just one of those cylinder head temperature sensors? What is the range of the gauge?
I know I could ask the seller, but I'm interested to hear your experience of the operation of this feature.
by Wack » Wed Mar 16, 2016 10:53 pm
I've had an Acewell for a few years now and it came with a water temp sensor which I didn't use. Someone told me I could set it into the cylinder head and it would still work, so after fitting it I then found out the speedo only has a limited temp range so looks like I may have wasted my time. I remember asking when I bought the unit from Quadtech if there was an air cooled sensor available but seem to think there wasn't along with an EGT sensor.
by Knowledge » Wed Mar 16, 2016 11:06 pm
That was kind of what I anticipated Wack. I think I will stick with the version with the fuel gauge version. If I get an exhaust temp sensor, I will use a gauge specifically for it.
by Wack » Thu Mar 17, 2016 6:42 pm
I'd recommend the Stage 6 EGT with a Chinese made sensor off Ebay. The Stage 6 probe is too short and tends to break easily.
by Knowledge » Sat Mar 19, 2016 8:47 am
Thanks Wack.
How far down the pipe is your sensor mounted?
by Wack » Sat Mar 19, 2016 8:38 pm
I always set them 100 mm from the piston skirt Martin.
Users browsing this forum: Bing [Bot] and 10 guests
