Just remembered what and why I had to machine hub ..........
The center disc /spinner is not exactly central in its std, set up but the rims will be . Just as a std hub is not central ,ie it's the thickness of one rim steel, over to the right to allow the two rim halves to sit central to the links. .....does that make sense ??
So when the center disc /spinner is flipped over this off centering is magnified . Only solution is to machine the one half of the hub , where it sits against the centre spinner. It was the caliper side from memory .
Hope this helps.
Russ
