Wassel battery
Wassel battery
Postby gp200ts1 » Wed Mar 30, 2016 6:56 pm
Looking for a slim battery for my Wassel conversion. Thing is to put it where I want it can't be more than 50mm wide. What are others using and anyone know of thin batteries of 5amp plus?
gp200ts1
Re: Wassel battery
Postby Toddy » Wed Mar 30, 2016 7:54 pm
I use one of these , bit wider than what you want though
http://www.blueboxbatteries.co.uk/batte ... ry/12v-4ah
Re: Wassel battery
Postby Nelly » Wed Mar 30, 2016 8:39 pm
There's all sorts of sizes of sealed lead acid batteries here....
http://www.battery-force.co.uk/category ... eries.html
Nelly
Re: Wassel battery
Postby terryj » Wed Mar 30, 2016 8:47 pm
i just brought an alarm battery of amazon i think sized to fit my battery tray and a bodged up clamp
terryj
Re: Wassel battery
Postby citydaz » Wed Mar 30, 2016 8:53 pm
I spent many hours loooking for that elusive thin / small battery that would fit in my tool box without taking up too much room.
In the end I got this: 12N5-3B 12V 5Ah Yuasa Motorcycle Battery.
It was the best compromise between small size and and Ah.
It important that you have proper screw on terminals rather than the slide on type as your wires will keep slipping off.
cheers & good luck!
citydaz
citydaz
Re: Wassel battery
Postby Toddy » Wed Mar 30, 2016 8:55 pm
citydaz wrote:I spent many hours loooking for that elusive thin / small battery that would fit in my tool box without taking up too much room.
cheers & good luck!
citydaz
I have slip on terminals if their covered and a good fit never had an issue :D
Re: Wassel battery
Postby rossclark » Wed Mar 30, 2016 9:09 pm
cheers & good luck!
citydaz
Exactly the same.
Re: Wassel battery
Postby Donnie » Thu Mar 31, 2016 10:48 am
already replied on scooterotica but
The space
ImageIMG_2857 1 by Donnie Canning, on Flickr
PX Battery tray with side dremelled off and attached to back of toolbox where your air filter normally goes.
ImageIMG_2858 1 by Donnie Canning, on Flickr
bought this http://www.ebay.co.uk/itm/301855488535? ... EBIDX%3AIT
which is a AGM better and service free version of http://www.mdsbattery.co.uk/shop/produc ... oupID=1029 which is what I did have and was tired through being run down
and all fitted.
ImageIMG_2864 1 by Donnie Canning, on Flickr
Donnie
Re: Wassel battery
Postby gp200ts1 » Thu Mar 31, 2016 8:16 pm
Donnie wrote:already replied on scooterotica but
The space
and all fitted.
That's what I've done on my gp but I've ended up with just 50mm to fit a battery into. Found this 12v 5ah battery which will fit but I can't find a stockist yet
It's a numax SLA5-12 it's 140mm long, 48mm wide and 103mm tall so it's an ideal size.
gp200ts1
