Scooterlam wrote:If I remember correctly, the recess on an Avanti head Is 2mm,
I measured a head and the head is 14 mm thick above the combustion area.
I would guess this is plenty to remove the "spigot" and basically start again.
Or drop Ron a line he might be able to sort you an unmachined head.
Think I understand what your saying, I'm running a 60 x 110 crank with 1mm base and 2mm head packers, no gaskets, so if I can get the transfer timings right with a base 3.5 mm packer , get head machined to 72mm dia, then dowel it centrally hopefully I should get the squish right?
Unless you can afford to add base packing because your port timings will allow it, you are going to have to recess the head, as you have suggested. Bear in mind the effect upon your head volume…
Rally220 wrote:Yes I'm going to use plasticene method as what Darrell says makes sense, especially with crap fuel about and fine tolerances required! Coaster who machined your head?
Adam_Winstone wrote:^... ha ha ha, I've been thinking about doing exactly the same to one of mine. Fools seldom differ, I guess (lol)!
