Jockeys Boxenstop
Jockeys Boxenstop
Postby Tractorman » Mon Apr 25, 2016 9:19 pm
Anyone know who sell Jockeys Boxenstop headlight kits for a series 2?
Re: Jockeys Boxenstop
Postby ToBoldlyGo » Mon Apr 25, 2016 9:56 pm
I'm not sure there is one specifically for the S2. But, it might be worth trying Tom David down in Cardiff. I think he's stocking them now.
ToBoldlyGo
Postby coaster » Mon Apr 25, 2016 11:12 pm
Tractorman wrote:Anyone know who sell Jockeys Boxenstop headlight kits for a series 2?
Scooter Centre Colne http://www.scooter-center.com/en/produc ... YS+12V+353
5W+HS1+H4+Lambretta+LI+Serie+2+TV+Serie+2?meta=7676153*scd_ALL_en*s19559408516144*jockeys*7*7*1*16
Postby Digger » Tue Apr 26, 2016 8:02 am
I bought mine direct from them. (Needs a far bit of electrical rejigging to make it fit)
Digger
Postby coaster » Tue Apr 26, 2016 9:11 am
I'm pretty sure I did too but I couldn't see them on the site for some reason :?
Postby Tractorman » Tue Apr 26, 2016 9:21 am
Thanks for the replies, Scooter-centre is out of stock, Tom David (via facebook) is not replying so I'll go for Jockeys. Just wondered if I could source one over here.
Postby Digger » Tue Apr 26, 2016 9:30 am
Tractorman wrote:Thanks for the replies, Scooter-centre is out of stock, Tom David (via facebook) is not replying so I'll go for Jockeys. Just wondered if I could source one over here.
Very straight forward and arrived within a few days.
Digger
Postby Donnie » Tue Apr 26, 2016 10:34 am
Same here, easy to fit too, be gentle with the fitting ring though, it needs a tweak, slowly slowly. also, you DO have to remove this Image and rewire slightly but its very straightforward.
Donnie
Postby MK Monty » Tue Apr 26, 2016 11:37 am
After recommendations on here I replaced the junction block with the Wago clip terminals. Available on eBay in 2 way up to 5 way you will have to loose the bullet ends first.
MK Monty
Postby Tractorman » Tue Apr 26, 2016 1:03 pm
They are good lights, then?
Postby Tractorman » Tue Apr 26, 2016 1:14 pm
MK Monty wrote:After recommendations on here I replaced the junction block with the Wago clip terminals. Available on eBay in 2 way up to 5 way you will have to loose the bullet ends first.
Which ones did you use, the lever or push in ones? Just thinking of the room in the handle bar top.
Postby Digger » Tue Apr 26, 2016 1:49 pm
Those lever ones look the business - just been watching a view videos on Youtube.
Digger
Postby MK Monty » Tue Apr 26, 2016 5:06 pm
I used the lever type, I was a bit concerned as to them popping open in use but they seem OK. I soldered all my wires so they had something to bite on but others may not.
MK Monty
Postby landybretta » Tue Apr 26, 2016 6:34 pm
I bought my series 3 direct from Jockeys.
Series 2 http://www.jockeys-boxenstop.de/shop/en ... 2v35-35w-4
landybretta
Postby bike grim » Tue Apr 26, 2016 8:14 pm
Any chance you could post a link up for the wago clips? I have a Jockey's light that I have put off fitting. I know there are a few different options on the wago clip terminals but don't know which is best
Postby Tractorman » Tue Apr 26, 2016 8:52 pm
bike grim wrote:Any chance you could post a link up for the wago clips? I have a Jockey's light that I have put off fitting. I know there are a few different options on the wago clip terminals but don't know which is best
Just put wago clips in ebay and they come up.
