harps2 wrote:OK - just rebuilt my first 1962 LI 125 and come to the moment of truth - starting her up............... all wiring plugged in correctly, new points adjusted, and leads and plug all new - test for spark - great looks very strong, fit the new plug (which also has new 175 top end) coughs and splutters the starts for a few seconds then stops and nothing - checked spark again still fine but looks and smells like she is flooded now.
Left for an hour checked spark - OK fit plug and tried to kick over and this is where the PROBLEM starts -- - kick start going down but not returning (pulling back by hand) at first then getting harder and harder to kick over and FINALLY jams solid.
Took plug out and try to kick over - kick start goes down slowly at first and then after a few kicks returns to normal turning engine over fine (kickstart return no problem) and showing good spark with plug on side of engine!
QUESTION - what is going wrong when I fit plug and turn fuel on? - any help or suggestions would be greatly accepted.
Thanks again
Alan (frustrated Lammy newbie)
harps2 wrote:Well you were right - casing off and problem found - kickstart shaft broken where it comes through the bronze bush (JUST LIKE THE PHOTO IN STICKY'S BOOK) - if you can give me some advice on best place to get a new one and anything I should be watching for on re-assembly again will all be appreciated !!
Thanks for pushing me to do disassy guys.
Alan
Users browsing this forum: Bing [Bot] and 12 guests
