GT186 / Series 2 / PHBH 30 / TSR Evo - Sudden Rough Running
Re: GT186 / Series 2 / PHBH 30 / TSR Evo - Sudden Rough Run
Postby Donnie » Sat May 14, 2016 12:41 pm
Cheers Adam, yeah have ordered another stator anyway, should really have a spare anyhoo for longer runs, but today I will get into the reeds and see if theres anything obvious there.
Donnie
Postby Donnie » Sat May 14, 2016 5:33 pm
Well it's not the reeds either, they look spot on and everythings tight.
Donnie
Postby rossclark » Sat May 14, 2016 6:05 pm
Has to be the weather then ;)
Postby burnside » Sat May 14, 2016 6:48 pm
Donnie wrote:
burnside wrote:Did you double up the reeds? Rich T recommends this if using an expansion on the 186 kit
I haven't actually but IF that was the cause why would it only now be an issue after several hundred miles?
Because one of your petals may have cracked/broken, doubling up helps prevent this from happening. Not saying it is this but worth doing.
burnside
Postby Donnie » Sat May 14, 2016 8:39 pm
rossclark wrote:Has to be the weather then ;)
LOL, well I hope not, seeing as I had the reed block out and had to drop the engine to do so i went ahead and dropped the cylinder etc off too to check.
no sticky or damaged rings, no head or base gasket leaks etc either. So now I guess the moneys on the stator :(
Donnie
Users browsing this forum: No registered users and 9 guests
