No lights or horn
No lights or horn
Postby Pops » Tue May 17, 2016 9:17 pm
I am trying to finish the restoration of my series 3 li 125 but having trouble getting lights,brake light and horn to work have checked connections and earths but no joy scooter starts and cutout switch works any suggestions gratefully accepted
Pops
Re: No lights or horn
Postby MickYork » Tue May 17, 2016 9:20 pm
Have you got voltage going into your regulator.......have you got voltage coming out ?
Postby Pops » Tue May 17, 2016 9:35 pm
Have not got a multimeter what's best way to check.I have upgraded to 12 volt electrics using kit from a f rayspeed
Pops
Postby Raveydavey » Tue May 17, 2016 9:54 pm
You can use a light to test a feed, one end on the regulator output, other to earth. You can send a current down the loom with a battery or battery charger and use the light at the other end to check you've the right wires. Sometimes it's just trial and error.
Make sure the horn is the right type, 12/ 6v ac / Dc etc
Raveydavey
Postby Andie » Tue May 17, 2016 10:22 pm
have you changed your loom?
Not sure what your 12v was, or if you have a battery - but mine is a Casatronic and i fitted mine as simply as possible, no battery - I retained my 'standard' L3 125 loom but upgraded it to a two wire brake switch by running in an extra wire-
Everything non-ignition, on mine, comes from the yellow wire (AC Lighting output), so the yellow wire from stator went into the regulator box and everything else (lights and brake light and horn) were soldered together onto one brass bullet connector that was matched to the output that corresponded to the yellow input.
worked for me. sometimes the connectors need pushing in.
failing that test meters are cheap! I use mine a lot to check earths Etc. - Andrew
Andie
Postby Toddy » Wed May 18, 2016 6:21 am
Do you have any pictures of your current wiring connections (Headlight Block / Regulator it may be something simple
Postby MickYork » Wed May 18, 2016 7:33 am
Pops wrote:Have not got a multimeter what's best way to check.I have upgraded to 12 volt electrics using kit from a f rayspeed
A cheap, but useable, multimeter will cost less than a fiver........i'd also buy a "Stickey's" manual (about £20) which contains all common wiring diagrams.
Postby Pops » Wed May 18, 2016 6:59 pm
I've got electronic ignition kit from af rayspeed (stator,cdi and regulator) have also fitted new loom,will have another try and sort out problem using all your suggestions thanks everyone for all your help
Pops
Users browsing this forum: Bing [Bot] and 21 guests
