RIMINI S2 42mm clubman vs S3 42mm clubman
Postby Covboy » Fri May 20, 2016 6:02 pm
http://www.riminilambrettacentre.com/en ... -6145.html
Has anybody tried one of these 42mm S1/S2 clubmans yet? I like the thought of standard looking s2 exhaust with a better performance
How do they compare with a S3 42mm clubman?
I was thinking of running my standard S2 150 with a 42mm pipe and a new 25mm dellorto just to give it a little bit more power..thoughts anyone???
Re: RIMINI S2 42mm clubman vs S3 42mm clubman
Postby Scooter Paul » Sat May 21, 2016 1:38 pm
I've got one fitted to my GP 200 engined Series 2. I wanted the original look. Sounds good. Not too loud or tinny. Can't really comment on full on performance as I'm still running in but it revs freely and I'm optomistic it won't choke at full throttle. Oh and it fitted without any fettling required!!!!
Paul.
Scooter Paul
Postby Rich Oswald » Sun May 22, 2016 10:55 pm
They're great, had one on my S1 after having a standard S3 Clubman on with no noticeable difference in performance.
Postby Covboy » Tue May 24, 2016 2:42 pm
Thanks for both replies -
@ Rich - just for clarification:- the 42mm S2 Casa exhaust performance is comparable to a S3 standard clubman, not a 42mm S3 Clubman....?
Postby Rich Oswald » Tue May 24, 2016 10:24 pm
Covboy wrote:Thanks for both replies -
Eh? Aren't they both the same thing?
Postby Covboy » Wed May 25, 2016 9:06 am
Hi Rich - I understood that the S3 42mm clubman exhausts (also known as big bore?) had different diameter downpipe / swan neck ( & probably internals) to the standard S3 exhaust which has a thinner downpipe???
Postby Rich Oswald » Wed May 25, 2016 12:20 pm
Covboy wrote:Hi Rich - I understood that the S3 42mm clubman exhausts (also known as big bore?) had different diameter downpipe / swan neck ( & probably internals) to the standard S3 exhaust which has a thinner downpipe???
Ok I was talking about a S3 Clubman and not a standard exhaust.
Postby Covboy » Wed May 25, 2016 4:16 pm
Thanks Rich. Ill think ill get one then..!
Postby Covboy » Mon May 30, 2016 11:19 am
Preferred...should arrive this week - will fit and report back...
Users browsing this forum: Bing [Bot] and 6 guests
