exhaust nuts
exhaust nuts
Postby Lammyal » Thu May 26, 2016 8:00 am
Hi, folks has anyone any tips on stopping the nuts on my exhaust manifold coming loose? one tightens up ok but I don't seem to be able to really get to the other to tighten it and in turn eventually loosens both, thanks
Lammyal
Re: exhaust nuts
Postby drivera » Thu May 26, 2016 8:10 am
Your probably best loosening the cylinder cowling and moving it as far as you can to give access to the nuts , make sure both studs are in good nick and apply Loctite to the brass nuts as you put them on , not forgetting to put a spring washer and thin washer between the brass nut and flange :)
drivera
Re: exhaust nuts
Postby Lammyal » Thu May 26, 2016 8:34 am
Cheers thanks, will give it a go, :D
Lammyal
Re: exhaust nuts
Postby CHRIS in MARGATE » Thu May 26, 2016 8:37 am
Got to nip em up tight first time and I always use Loctite on brand new studs and brass nuts. I cut a spanner down to give better access to the flywheel side. I also have 3 different make spanners all identified with tape in the toolbox to accommodate qll the little 1/8 turns when the spanner won't fit on.
Terrible design !
Re: exhaust nuts
Postby Meds » Thu May 26, 2016 10:12 am
Nord-lock washers or Knuts.
M7 Knuts require a smaller spanner which makes it a little easier to get into the exhaust nuts but they aren't cheap.
Do a search on here or scooterotica there is a whole thread on this.
Meds
Re: exhaust nuts
Postby Lammyal » Thu May 26, 2016 10:19 am
Hi, thanks for the ideas, im going to get new studs too and ive just seen locking kit with wires from andy francis but will use all the other ideas too, cheers
Lammyal
Re: exhaust nuts
Postby Covboy » Thu May 26, 2016 10:56 am
hi
one of the members on this forum has a shop - I have bought these and they are good.
http://k2customs.co.uk/products/extende ... -lock-wire
Re: exhaust nuts
Postby CHRIS in MARGATE » Thu May 26, 2016 11:02 am
They are such a simple yet brilliant idea. Just wish they would fit on my SCOOTRS downpipe !
Re: exhaust nuts
Postby Norrie Bodge » Thu May 26, 2016 12:11 pm
Try.... Chain guide tab washer cut in half, wi holes drilled 7mm
Works a treat !
Norrie Bodge
Re: exhaust nuts
Postby Warkton Tornado No.1 » Thu May 26, 2016 2:54 pm
Currently I run long plain 10 mm hexagon nuts (run a M7 tap through an M6 nut. They are the same pitch) with lock wire between the two pulling each Clockwise.
It’s an easy fix & amazing how the smaller hexagon gives so much more spanner room or even allows a ¼” drive socket to fit. ;)
Re: exhaust nuts
Postby Lammyal » Thu May 26, 2016 5:00 pm
Cheers more good ideas, thanks
Lammyal
Re: exhaust nuts
Postby Marty ULC » Fri May 27, 2016 1:37 pm
Norrie Bodge wrote:Try.... Chain guide tab washer cut in half, wi holes drilled 7mm
Works a treat !
That's what I do too. (Thanks to Sticky's book)
Marty ULC
Return to Carburettors
