Adam_Winstone wrote:Agree 100%, this is a fascinating insight into what is possible with stage by stage attention to detail. I also remember a quote somewhere from Dave Webster or Ralph Saxelby that their take on tuning was to get the biggest return for the smallest changes first, which reminds me of this attention to detail approach.
Johnny, don't overlook the fact that a main reason for addressing the squish in this feature was that the compression was low and the 1.5 squish reduction bumped up the compression to a better figure, rather than it just being about getting the squish right.
A great read and I'm aware that the second part of this should be out now and I'm itching to read it
Adam
johnnyXS wrote:Adam_Winstone wrote:Agree 100%, this is a fascinating insight into what is possible with stage by stage attention to detail. I also remember a quote somewhere from Dave Webster or Ralph Saxelby that their take on tuning was to get the biggest return for the smallest changes first, which reminds me of this attention to detail approach.
Adam
I hadn't forgotten Adam . Squish and compression are synonymous and cannot be considered seperately, any change in squish will result in a change of compression naturally . I suppose the point that I was trying to put across was that with a little attention to basic detail there are potentially massive gains in performance to be had for nothing by all of us.
How many of us diy engine builders measure and set their squish accurately or even appreciate the effect of compression ? for that matter how many of us could quote the compression figure for their engines 1 in a 100 ? probably less than that, yet I'm willing to bet that 95% of those same owners have spent a lot of money on expansion boxes and bigger carbs in pursuit of power .
Engine building and performance is all about understanding how things work just as much as attention to detail .
Your reference to the old adage 'do the things that cost the least and gain the biggest performance increase first ' is so often overlooked these days.
its much more sexy to bolt on some really expensive shiny bling rather than get your points and staic timing set up accurately. Alexander Graham Bell and David Vizard were both exponents of this approach as far back as the 60's .
holty wrote:johnnyXS wrote:Adam_Winstone wrote:Agree 100%, this is a fascinating insight into what is possible with stage by stage attention to detail. I also remember a quote somewhere from Dave Webster or Ralph Saxelby that their take on tuning was to get the biggest return for the smallest changes first, which reminds me of this attention to detail approach.
Adam
i agree with all of the above, optimising your squish will deliver more power and torque right across the rev range, making the engine seem bigger in capacity, it should also run cooler, giving better fuel consumption as well. i did at one time have a taffspeed 240 which ran very badly, hard to start, siezed a lot, in the end i stripped it,the piston was badly worn,i took the barrel to beedspeed were mark broadhurst honed the barrel and sold me a new piston and head profiled to the piston, i cant tell you the transformation of that engine by just getting the squish correct shape and thickness, had more power everywhere in the rev range, unbelivable improvement, so fast i crashed the bloody thing. i did go on to own a mini and tuned it myself using a book by david vizard as mentioned above, very clever man.
johnnyXS wrote:
Do you know what the peak squish velocity is for any of your engines and why its important to know ? I know I don't lol![]()
Eden wrote:[
I haven't read the article as I dont buy scootering mag or buy into its ethos so I have no idea what Darrel says in it.
Does he mention that the velocity is chosen depending on how the motor is intended to be used?
