Frame cut
Frame cut
Postby gizmo » Sun Jun 05, 2016 4:17 pm
Want to cut an Li frame to suit GP bodywork, any advice or is it just a matter of cutting 20 odd mil off and getting steering race turned down to fit.
gizmo
Re: Frame cut
Postby ToBoldlyGo » Sun Jun 05, 2016 5:20 pm
Swap it for a Spanish frame.
ToBoldlyGo
Re: Frame cut
Postby Digger » Sun Jun 05, 2016 6:03 pm
ToBoldlyGo wrote:Swap it for a Spanish frame.
That isn't going to help him.
Digger
Re: Frame cut
Postby gizmo » Sun Jun 05, 2016 6:13 pm
It is a Spanish frame. I was going to do it as a special but my love of GP's has got the better of me. It owes me too much to sell it and it's been altered to take an aero filler cap
gizmo
Re: Frame cut
Postby MickYork » Sun Jun 05, 2016 6:19 pm
I think you're right, cut the fork stem down and job done.
I would consider offering it up as a swap though, as the fact the log book will always be Li and it will look like a GP, might worry some people
Re: Frame cut
Postby modster79 » Sun Jun 05, 2016 6:47 pm
I did it years ago, used a pipe cutter that cost a couple of quid to cut the stem. The pipe cutter gives a good straight cut.
modster79
Re: Frame cut
Postby Knowledge » Sun Jun 05, 2016 11:56 pm
Hold on, it is not quite that simple.
The top of the steering column tube is machined at the top to a depth of about 15mm to suit the GP top steering bearing race. When you cut the top off the steering column tube, you lose this machined recess. When you offer up the bearing track, it doesn't fit. It is too big and hardened, so it is very difficult to machine.
To overcome this, I used a chrome ring and associated bearing, which has a smaller OD. I then cut all the ring off (except the lug that forms the steering-lock stop) so it becomes an adaptor between the cut-down steering column tube and the bearing race. I do this by machining-down the outside of the remaining chrome ring to match the ID of the inside of the steering column tube. I hope that makes sense.
It is a bit of a waste of a chrome-ring, but it works.
Users browsing this forum: Paulusgnome and 11 guests
