model c gears / clutch causing engine cut out
Postby johncas » Mon Jun 06, 2016 9:46 am
On my model c when I go to change gears there is like a crunch \ grind sound then engine cuts out the clutch leaver is sort of loose not tight is it the clutch is not engaging fully when leaver pulled in or is there some adjustments need doing
johncas
Re: model c gears / clutch causing engine cut out
Postby jbcollier » Mon Jun 06, 2016 2:07 pm
Well, the first place to start would be to adjust the clutch properly. The clutch is adjusted at the engine first and then the lever freeplay is set.
jbcollier
Postby jbcollier » Mon Jun 06, 2016 2:38 pm
jbcollier
Return to Pre 57
