by Strummer10 » Sun Jun 19, 2016 8:17 am
Guys, does anyone know where you can buy the metal kits that you clamp onto an existing 'sprint rack' so it turns it into a bigger rack for carrying your tent and luggage ? I'm sure it makes the rack more rectangular and uses 'u clamp' bolts like an exhaust ...
Strummer10
by gaz_powell » Sun Jun 19, 2016 12:11 pm
it was the scooter republic that was doing them
by ian i.o.w » Sun Jun 19, 2016 5:09 pm
Hi cut a bit of ply and sit it on your existing rack easy to remove
ian i.o.w
by Hoss » Sun Jun 19, 2016 5:59 pm
Cut some plywood. Drill holes equally spaced around edges for bungy hooks. Drill through ply for bolts and match the holes onto a strip of metal which then slots under existing rack and when bolt both together you have a secure, cheap large rack which can easily be removed when not needed.
Hoss
by gaz_powell » Sun Jun 19, 2016 11:42 pm
Ikea worktop trevit - like a wire rack from an oven but thicker bars and 4 quid in stainless. Tie wrap to sprint rack
Users browsing this forum: Bing [Bot] and 12 guests
