jonno wrote:Im running a sweetbreathe filter on my muggy 225 with lth reed valve.I had to fit the sweetbreathe to get enough air to the carb
Re: Not enough air
Post by jonno » Wed Jul 06, 2016 3:58 pm
Mag seal had gone,replaced and all a lot better.I do have a flat spot between 1/4 and 1/2 throttle.Put on the choke and it gets worse which I guess means its a rich flat spot.Would a leaner slide make it better? have read AV jets have a flat spot.
Post by jonno » Sat Jul 09, 2016 10:12 am
Im pretty sure the set up was the same as camel,perhaps I remember it running better as wishful thinking.Im not sure about going down to a 262 warkton.I ran an x7 needle and it was a bit lean at about 50mph.Im doing plug chops btw.It was better with an x2 needle.
Been checking 2 stroke plug colour on the web and motox sites suggest a white plug is goodIm sure its choccy brown for Lambrettas tho.
jonno wrote:I
Users browsing this forum: No registered users and 3 guests
