Warkton Tornado No.1 wrote:I feel sure that those in the know might confirm this, or otherwise, but I believe that the MOT procedure cannot enforce the removal of the panels, not even for VIN verification.![]()
Obviously, you are trying really hard to be co-operative to the tester, so there should be no concern if you explain your dilemma, just as you have on this Forum.
They are unlikely to take issue with you & a copy of the number & any previous MOT certificates &/or log books/equivalent are all going to add to your integrity.
by Digger » Fri Jun 17, 2016 8:48 am
You would need to remove a panel, if fitted, on most Lambretta's to verify the frame number if you are getting an MOT as part of the registration process.
I've a Serveta LIS 150 with it on the right-hand legshield strut.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
