Got a Rocho style clutch (actually built by Tarmac Tickler) lambretta 46t crown wheel with Aprilla RS125 basket riveted to it with Aprilla plates and steels. I was experiencing clutch drag so adjusted a couple of turns and all seemed ok took it down to put on Dyno and whilst on the Dyno the clutch appeared to be slipping at speed, so readjusted then as the clutched was pulled in to reduce speed it started to rev high with clutch out. when it eventually stopped it appeared the clutch cable may have snapped but on closer inspection the clutch arm seemed really loose (no resistance from the clutch springs) after stripping down I found the clutch nipple ,Li type, had melted/fused to both the pressure plate and the clutch arm cam. Has anyone else experienced this? Do they need to be set up with a little drag? And what type of oil should be used? I did have standard ST90 in it
Thanks in advance
Gazza
