Lambretta Contact tester 0517C
Postby Bettagetabrettabolti » Fri Jul 22, 2016 6:21 am
Chaps
I have one of the original tools sold by Innocenti that tests your contact breaker (points to you and I).
Does anyone know where to connect up the two crocodile clips and also have any instruction on how to use it.
Bolti
Re: Lambretta Contact tester 0517C
Postby johnnyXS » Fri Jul 22, 2016 6:56 am
you have a tool and don't know how to use it ?! :lol: ......
just kiddin.
Without a picture or product No I would imagine that what you have is essentially something that tells you when your points are just opening to set your timing.
If that is the case then you'll need to attach one clip to the chassis (or battery negative if you have one) and the other needs to connect to the insulated side of your points
johnnyXS
Postby coaster » Fri Jul 22, 2016 10:12 am
I used to work for a large concessionaires for Lambretta, Yamaha, Suzuki, Kawasaki, Triumph, Norton and BSA in Ipswich when I first left school and the Lambretta ignition tester was in constant use on everything that came in the workshop including the Rickman Matisse race bikes that they sponsored. Johnny XS has the connection correct and from memory there should be a button to push to activate the dial....it was a loooong while ago :oops:
Postby johnnyXS » Fri Jul 22, 2016 10:55 am
coaster wrote:..it was a loooong while ago :oops:
back when you and I wore short trousers coaster :lol: :lol:
johnnyXS
Postby Bettagetabrettabolti » Fri Jul 22, 2016 1:13 pm
Thanks guys - still wearing the shorts in this heat! Not sure how you up load pics onto this site but yes it has a test button and a dial.
It has a picture of the contact tester in the Lambretta Servicemans book on page 71 for those interested but never said how to connect it up.
I will play with it now you have given me a clue and see how I get on.
As always thanks for your help guys
Bolti
Bolti
Postby johnnyXS » Fri Jul 22, 2016 3:20 pm
fook me thats complicated :? reminds me of school ....'the opposite angle of the dangle is equal to the sum of the square of the ........blah blah......gazes out the window at the girls playing rounders . :roll:
Think I'll just stick to using my multimeter :lol:
johnnyXS
Return to Pre 57
Users browsing this forum: Google [Bot] and 15 guests
