urgent..change front sprocket engine in?
Postby swissdean » Fri Aug 05, 2016 5:47 pm
Hi, I;m trying to change front sprocket without removing top end and engine in bike. have in 2nd gear and daughter stamping on the rear brake but i just seem to be winding against the spring with no give in the bolt..bike also sliding along the bench and rear wheel slightly turning at max elbow torque!
any quick tips or tricks out there, hoping to sort out tonight..next plan is clutch plates out and clutch holding tool bolted in place
cant find my impact driver as was planning to give that a go also
thanks
swissdean
Re: urgent..change front sprocket engine in?
Postby Warkton Tornado No.1 » Fri Aug 05, 2016 6:03 pm
I would sooner use an impact gun, too, but as you say....
I can't really recommend this, but have done so myself, so:
Jam something alloy or copper, brass in the chain to clutch sprocket 'nip'
You shouldn't damage anything if the material used is softer than steel.
Gulp! :?
Postby MickYork » Fri Aug 05, 2016 6:11 pm
bit of a "roadside repair" and not really recommended but !! we jammed a cloth in the chain which jammed everything up nicely....
....................or use a flywheel holding tool
Postby Donnie » Fri Aug 05, 2016 6:18 pm
likely to twist the crank using a flywheel holding tool.
Not sure why your not just using the clutch basket holder, you must have one if you are planning on removing the clutch?
Donnie
Postby Wack » Fri Aug 05, 2016 6:19 pm
Once you've stopped the chain turning use a good 6 sided socket then take up the spring tension and give the ratchet a sharp jab with the palm of your hand. The shock should break the threads grip, other than that someone has over tightened the bolt in the past. Torque to 25 ft/lb up to 30 on a tuned motor.
Postby Wack » Fri Aug 05, 2016 6:23 pm
Here's something I knocked up to do swift sprocket changes on race motors Image
Postby swissdean » Fri Aug 05, 2016 6:31 pm
thanks everyone, really swift replies..much appreciated, ...will be trying clutch holding tool now, but really like that last gadget..someone should make and sell those..the 6 sided (and i read elsewhere on here) grinded down socket will be next on my shopping list for future use
swissdean
Postby Tractorman » Fri Aug 05, 2016 8:07 pm
Wack wrote:Here's something I knocked up to do swift sprocket changes on race motors Image
Excellent!
Postby Wack » Sat Aug 06, 2016 11:28 am
You may be right Eden but if you think about it the load is spread out over two hardened teeth against a piece of mild bar so in theory it's probably better than straining a chain and who wants the hassle of pulling a clutch to pieces just to change a sprocket?
Postby Scooterlam » Sat Aug 06, 2016 1:18 pm
For us "Modernists" using an af clutch you can hold the clutch without dissasemblimg the clutch.
But rubber handle of pliers doez it for me.
Scooterlam
Postby Tractorman » Sat Aug 06, 2016 3:44 pm
Wack wrote:You may be right Eden but if you think about it the load is spread out over two hardened teeth against a piece of mild bar so in theory it's probably better than straining a chain and who wants the hassle of pulling a clutch to pieces just to change a sprocket?
Plus you are only torqueing up to 25ftlbs.
Postby jonno » Sat Aug 06, 2016 4:05 pm
Piece of rope down plug hole works a treat. 8-)
jonno
Postby isthmus » Sat Aug 06, 2016 4:17 pm
hi all,just a thought,if you use a longer shaft on your nut you will need less force to undo your nut,just a thought.
isthmus
Postby Simon ELC » Sat Aug 06, 2016 9:33 pm
Great idea I made something similar for my Dragster.
Simon ELC
Postby swissdean » Sun Aug 07, 2016 7:43 am
clutch out and clutch holding tool it was, a doddle thereafter..btw, I replaced with a Jockey Boxenstop chain guide, with it pushing down and then measured the float/slack at top near the front sprocket..set to between 6m and 8mm, loctited two screws in place...stickys book says 6m is about right ..just interested what others do
swissdean
Postby HxPaul » Sun Aug 07, 2016 2:49 pm
What we used to do years ago,(and not recomended )is put a screwdriver on the bottom run of the chain and turn sprocket until the screwdriver was trapped between the chain and the bottom of the front sprocket.Fasten on the top run.
Postby Paulnobodyimportant » Sun Aug 07, 2016 5:25 pm
Chain tension OK at 6-8mm.
Anyway, read your thread earlier this week and took note for my re-build. However, yesterday, between other things, I managed to snatch some time to re-build top end ready for air leak check, once all sealent had done its stuff. Stood back to admire my work and my draw dropped.
Clutch plates out next!
Paulnobodyimportant
