Paul_from_Thornbury wrote:Just changed my inline spare wheel holder from the Cuppini style to the one you have here, as the Cuppini one which was made out of sheet plate and kept vibrating and snapping.
having just fitted my one like yours I note the same issue you have is that the two half clamps come together and don't meets any bolt holes if you want the wheel mounted as yours with the spare holes at 3/6/9/12 o clock to mount an oil can holder.
When the clamps come together like this they don't even catch the wheel rim as it is scalloped. So what exactly is clamping your wheel or is it just wedged between the holder and the toolbox door.
I only have a 3.00x10 tyre and its a squeeze with the tyre wedged against the toolbox door, at least there was a small gap at the toolbox with the Cuppini style.
Can you send me some close up pictures of the clamp and the toolbox?
cheers Paul
Paul_from_Thornbury wrote:Do your clamps touch the wheel rim or not?
Attached is a picture of mine when I put the spare bolt holes at 3/6/9/12 o clock positions?
My spare is just jammed between the rack and the toolbox door and isn't being held by the clamps.
I've seen pictures on here where the clamp actually uses one of the spare holes, but that makes it difficult to fit an oil tank holder as all the holes are then not in good places and you definitely need a scooped toolbox door.
Topgearskin wrote:Such a great looking Scooter and (I'm sure) well worth the ball ache in the end!
I'm interested to hear your views on that Seat? is it as comfortable as it looks?
byron wrote:only just seen this Paul!
looking good.
and glad all the electrics worked again after the rebuild, following our facetime sessions
wellerchap wrote:Great work dude - and nice to see a homage to a cherished garment too![]()
