HT coil mounting
HT coil mounting
Postby eyeguy » Wed Aug 31, 2016 4:33 pm
I am having trouble figuring out the proper mounting for my Li 62/3 125. The picture shows what I have. The anti vibration pad came off my series 2. I have seen different options. Would someone have a picture you could post.
eyeguy
eyeguy
Re: HT coil mounting
Postby Dimitrios_231 » Wed Aug 31, 2016 7:39 pm
Dimitrios_231
Postby eyeguy » Wed Aug 31, 2016 8:42 pm
Thanks Dimitrios, just what I needed. The bolts I have are way to long. I will get shorter ones.
Eyeguy
eyeguy
Postby eyeguy » Thu Sep 08, 2016 8:02 pm
So After a couple weeks of trying to find the original coil bracket hdwe, I decided to restore the one I have. I think it turned out very good. Now my question is does this look like the proper way it is to be mounted?
Look at photo above to compare the final restoration of the antivibration pad and parts
eyeguy
eyeguy
Postby Dimitrios_231 » Thu Sep 08, 2016 8:17 pm
You don't need the spacers,just shorter bolts ;)
The spacers are used on the later models that don't have the pad.
You are also missing this part,like S1 and S2.
http://sco1.scooter-center.com/en/produ ... ZUENDSPULE
If you want you can use the spacers without the pad.
Dimitrios_231
Postby Covboy » Thu Sep 08, 2016 8:24 pm
Eye guy
If you want one I'll send you my old one. PM me
Postby Dimitrios_231 » Thu Sep 08, 2016 8:44 pm
Dimitrios_231
Postby eyeguy » Thu Sep 08, 2016 9:14 pm
Hi dimitrios, I have the grounding piece on order. should be here soon. Am I correct in thinking that the piece hits the frame to make a ground?
eyeguy
eyeguy
Postby eyeguy » Thu Sep 08, 2016 9:19 pm
Dimitrios, Is that diagram for the early series 3?
eyeguy
Postby Dimitrios_231 » Thu Sep 08, 2016 9:39 pm
Yes,from an early S3 parts book with 4 pole ducati ignition.
You just need to rotate the set up in your mind ;)
don't know why the Italians drew it this way,they were trolling us :mrgreen:
In theory yes,it is an earth plate,it connects the support plate (23) that fixes the coil with the frame (earthed) screws.
Dimitrios_231
