Gori seat/airflow
Gori seat/airflow
Postby eyeguy » Tue Sep 27, 2016 4:45 pm
May have made a mistake. Got the gori seat that fits flat against frame. didn't realize I had to remove air intake. where will the air come from? I am trying to sort out what filter to use on my dellorto 25mm PHBL carb as I now see that the standard box wont work. Any suggestions
eyeguy
eyeguy
Re: Gori seat/airflow
Postby hullygully » Tue Sep 27, 2016 5:50 pm
drill the air box with several 10mm dia holes in the sides. 8-)
Postby citydaz » Tue Sep 27, 2016 7:11 pm
remove the airbox, fit a medium range tank, add a remote ram air filter onto your carb ;)
citydaz
Postby eyeguy » Tue Sep 27, 2016 7:35 pm
Hey Citydaz, is there another tank besides the original or the long range tank?
eyeguy
eyeguy
Postby eyeguy » Tue Sep 27, 2016 7:36 pm
I am using the original
eyeguy
eyeguy
Postby Adam_Winstone » Tue Sep 27, 2016 9:44 pm
Pal of mine fitted a slope back seat to a GP that he restored and it seriously limited the airflow under to the original airbox, so much so that when he took it to have it dynoed they couldn't get the motor to breathe cleanly as regardless of whether the air/fuel ratio was correct. The motor simply couldn't breathe enough volume of intake and he was given the option of changing the seat or the intake system. He swapped to a remote filter and the running and jetting requirement instantly changed.
I'd suggest that you have the same decision to make, change the seat or change the intake.
Adam
PS - You're not the first to make this mistake, nor will you be the last.
Postby eyeguy » Wed Sep 28, 2016 1:30 am
Hi Adam, I did order a remote filter. What if I remove the air box completely. No need for it anyway. Would this be work well.
Eyeguy
eyeguy
Postby Adam_Winstone » Wed Sep 28, 2016 11:47 am
Yes, get rid of the airbox.
Postby eyeguy » Thu Sep 29, 2016 3:53 pm
thanks Adam, Airbox gone
eyeguy
eyeguy
Users browsing this forum: Bing [Bot] and 6 guests
