Post by EddieStone » Wed Sep 28, 2016 11:38 pm
I always thought that the piston could suck in air through a leak in the manifold leading to a lean mixture.
Warkton Tornado No.1 wrote::!:Post by EddieStone » Wed Sep 28, 2016 11:38 pm
Of course it can, with disastrous results![]()
It's a struggle to get a point across sometimes, but I would imagine that anybody that has used an oxy-acetylene torch would be able to relate to how the temperature in the flame rises with the introduction of more air. The flame heat changes from that of being able to,say, braze, to being able to cut through steel plate
Post by coaster » Thu Sep 29, 2016 4:01 pm
I don't think anyone is in any doubt as to the consequence of running lean, the poster is asking how big an effect a leaking gasket would have on the mixture i.e. would a slight blow be any thing to worry about?
Post by Chadley » Thu Sep 29, 2016 10:03 pm
Okay. An exhaust leak is bad. Modern exhaust copper gaskets are crap and cause leaks despite a short term bodge solution using silicon sealant. The solution is:?
My guess is to try a different gasket type such as the fibre type?
Users browsing this forum: Google [Bot] and 38 guests
